gateway无法接收到RAK812发送的数据
  • 问题:
    按照RAK812 AT命令用户手册将RAK812节点配置为LoraP2P模式,并向网管发送数据包,网关能够正常收到RAK812发送的数据包,修改网关的配置文件,并将RAK812配置为Lora WAN模式,按照手册上4.3节的范例将节点配置成ABP激活模式,并发送数据包,网关上没有接收到任何数据,等待一段时间后,网关能收到其他非RAK812节点发送的数据,但始终无法收到RAK812的数据。网关连接上了loraserver服务器,但无法收到RAK812数据,这是怎么回事?
    packet_forwarder的版本:https://github.com/Lora-net/packet_forwarder.git
    节点上的AT指令为 RAK812 AT命令用户手册的4.3和4.4节所示。
  • RAK812是470的,网关的配置如下
    "SX1301_conf": {
    "lorawan_public": true,
    "clksrc": 1, /* radio_1 provides clock to concentrator /
    "radio_0": {
    "enable": true,
    "type": "SX1255",
    "freq": 470700000,
    "rssi_offset": -166.0,
    "tx_enable": false
    "radio_1": {
    "enable": true,
    "type": "SX1255",
    "freq": 471700000,
    "tx_enable": false
    "chan_multiSF_0": {
    Lora MAC channel, 125kHz, all SF, 868.1 MHz /
    "enable": true,
    "radio": 0,
    "if": -400000
    "chan_multiSF_1": {
    Lora MAC channel, 125kHz, all SF, 868.3 MHz /
    "enable": true,
    "radio": 0,
    "if": -200000
    "chan_multiSF_2": {
    Lora MAC channel, 125kHz, all SF, 868.5 MHz /
    "enable": true,
    "radio": 0,
    "if": 0
    "chan_multiSF_3": {
    Lora MAC channel, 125kHz, all SF, 867.1 MHz /
    "enable": true,
    "radio": 0,
    "if": 200000
    "chan_multiSF_4": {
    Lora MAC channel, 125kHz, all SF, 867.3 MHz /
    "enable": true,
    "radio": 0,
    "if": 400000
    "chan_multiSF_5": {
    Lora MAC channel, 125kHz, all SF, 867.5 MHz /
    "enable": true,
    "radio": 1,
    "if": -400000
    "chan_multiSF_6": {
    Lora MAC channel, 125kHz, all SF, 867.7 MHz /
    "enable": true,
    "radio": 1,
    "if": -200000
    "chan_multiSF_7": {
    Lora MAC channel, 125kHz, all SF, 867.9 MHz /
    "enable": true,
    "radio": 1,
    "if": 0
    "chan_Lora_std": {
    Lora MAC channel, 250kHz, SF7, 868.3 MHz /
    "enable": true,
    "radio": 1,
    "if": -200000,
    "bandwidth": 250000,
    "spread_factor": 7
    "chan_FSK": {
    FSK 50kbps channel, 868.8 MHz */
    "enable": true,
    "radio": 1,
    "if": 300000,
    "bandwidth": 125000,
    "datarate": 50000
    "gateway_conf": {
    "gateway_ID": "AA555A0000000000"
  • 你好
    你试过OTAA 模式吗?另外你的服务器是你自己搭建的还是使用官方的?
    建议按照我们的文档先尝试链接TTN
  • @steven OTAA模式也试过,网关也收不到包,这和服务器关系不大,网关先收到数据包然后再将数据包转发给服务器,现在我的网关连RAK812发的数据包都收不到,收到数据包再谈服务器,RAK812上的操作步骤是严格按照文档上进行的。
  • OK ,来我们公司现场解决吧 。 谢谢
登录后回复
与 RAK支持中心 的连接断开,我们正在尝试重连,请耐心等待
